Logan
I plan to switch to EFI when I can afford it and would like to set up my new tank NOW to accept Aeromotive's in-tank Phantom 340 Fuel pump in the future and plate it closed for now.
I plan to cut a fuel pump access hole in the trunk floor [thanks for the idea goldduster318] so it will not be necessary to recess the pump into the tank.
Anyone know the hole size for the tank? Bolt pattern?
I checked Summit's Aeromotive offering to see if I could buy a gasket to get the necessary dimensions but no luck.
