Well I tried the electrical and ignition and only got one set of pictures so lets see if I can snag a few more. Looking to see how people mounted there aftermarket fuse box.
I mounted mine to the glove box door. I made a plate then mounted the plate and box to the door. I also made a plate and mounted the voltage regulator, which you can kind of see in the picture, as well as a ground bus bar to the the underside of the dash. Everything is pretty accessible.
