What year is your car? Classic Air's advertising says that the "Perfect Fit System" works with '66 and up.
This is not correct. I have a '63 Dart GT convertible (relevant area of the firewall is the same '63 to '66). The kit will not just bolt-in. Some, but not all of the holes are correct where the old heater motor went through the firewall. A bracket had to be fabricated to support the front of the evaporator. Installation of this bracket would be impossible without the dash removed from the vehicle. The block-off plate for the right-side "summer door" inlet cannot be attached with the supplied two screws. After drilling a hole, one screws will install, but the shape of the inlet precludes installing the other screw. You'll have to glue that end. I don't like losing the summer door.
The condenser is too wide. The pre-bent refrigerant lines are useless on the '63 to '66. You'll have to buy another condenser and form your own lines.
The slant six compressor bracket mounts the compressor too far forward. It comes with a double pulley that mounts to the vibration dampener, with the inner portion of the pulley intended for the power steering belt and the outer portion for the compressor. With the pulley installed, the fan must be mounted further forward, leaving no room for the radiator.
The kit is probably a breeze in a '67 and up a body. That is what it really is designed for. On an earlier a body, too much fabrication is required to justify the price. If I could do it over again, I'd go another route.
Hope this helps.
--Walt Jackson
