ACME SS
I own and have used my Fastrax alignment tool to align several cars with great success. The biggest drawback however is that I can not watch the changes to both caster and camber as I make them and the 2 upper eccentrics to adjust both caster and camber is causing my brain to overheat. Is anyone aware of an online calculator in which you could input the position of the eccentrics and the resulting camber caster degrees and it would suggest changes? I don't suppose there is any monetary value for anyone to have developed this but its worth asking.
I replaced my stock control arms and strut rod with QA-1 parts and while I can get much more caster and camber adjustments out of the new parts, getting the caster and camber to BOTH be in the range is killing me.
