TheDeputy
- Joined
- Aug 20, 2008
- Messages
- 227
- Reaction score
- 4
I just had my 68 valiant aligned using specs found on this site. The car now has the factory 9" drums. The plan however is to convert it to big pattern F-body spindles.
I have put all new bushings and ball joints in my current a-arms and lower arms.
What to do with the upper ball joint? I've been thinking about using the tapered adapter, found at doctor diff, so I can retain the 72-down upper balljoint. Is this any good?
And do I need to realign it after the spindel swap has been made?
Or should I just get new upper ball joints as well?
What about the bushings in the A-arms, Will they fit in the 73-up A-arms?
Thanks,
Antoon
Thanks,
Antoon
