alignment specs
Ironmike
Western Pa
Have an appointment Monday to FINALLY get lined up and drive this thing. All new front end parts and I think I'm looking ok to drive 7 miles to the shop.
I really need a good set of specs for radial tires. My car is a 1971 Demon with manual steering. Mostly cruising and a bit of drag racing. Maybe only once a month or so.
Did a search and found a few sets of numbers, but really need some hard figures for my kind of driving.
Here's some stuff I saved:
from here:
http://www.forabodiesonly.com/mopar/showthread.php?t=60712
"Have them start with the front cam all the way out and the rear cam all the way in. Move the rear cam out until camber is in spec (1/2 deg. neg is good). This is the most positive caster that is available without new parts (offset bushings, tubular upper control arms, etc.). All of this is AFTER setting ride height. I usually set ride height with about an inch between the LCA bumper and the frame, then even the sides up. "
http://www.allpar.com/history/mopar/front-end-alignment.html
http://www.moparmusclemagazine.com/howto/mopp_0701_1968_plymouth_gtx_suspension/index.html
from here:
spot on!
