BadAss71
Let's Go Brandon
Ok guys, just wanted to give my opinion of these two suspension systems as I have installed and driven both of them. I have installed two Alterkation units and just installed my first, and hopefully last Magnumforce system. First off, quality. Both systems are nicely designed and the craftsmanship is top notch. Secondly, installation. I found the Alterkation to be way simpler and less work to install vs the Magnumforce. The Magnumforce requires additional bracing to be welded to the front frame to prevent the coilovers from ripping through the shock mounts. The Alterkation requires zero welding and bracing. A huge plus in my book. Also, the instructions for the Magnumforce are so damn vague. Horrible actually. Driveability is identical betwen the two, you can't tell the difference. Visually the Magnumforce is more appealing I think. So that about sums it up. When I have enough pennies saved up, Alterkation will be my choice hands down.
