SteveM
Active Member
Any ideas on how to unstick the long alternator bracket bolt that goes into the block through the water pump and timing chain cover? I sense anymore torque and it will break and nowhere to apply penetrating oil.
What about lightly tapping an impact driver, to see if you can break it loose?
A little outside the box if other suggestions don't work out.......
Could you drill an 1/16" hole or two into the bolt boss of the pump house to get some penetrant in there?
