I need the little triangle bracket for the alternator on a small block
What year? cast iron pump or aluminum? I have
both style. do you need the spacers and bolt adjuster arm included. I just took aluminum style off a 75
Can you post me a pict
Mine is the aluminum can you send me a pict of what you have?What year? cast iron pump or aluminum? I have both style. do you need the spacers and bolt adjuster arm included. I just took aluminum style off a 75.
Triangle and spacers would you have pulleys also ? with power steering and AC ?The one you need looks like this. but it will be cleaned and painted. You only need the triangle is that correct? Or do you need all the parts?
one triangle
two bushinss
one long 3/8 16 bolt
one short 5/16 18 bolt
one adjustment bracket
