Alternator only.. What single groove puley??
1969ProDart
Florida
Ok getting my 383 together, I plan to have the motor running on one belt which is the alternator. ( electric water pump) looking for a single grooved CRANK pulley to run. What should I get.
Thanks
what kind of alternator are you running? look on ebay for a seller by the name of triodediode he sells pullys a quick search on ebay will yield any pully you need
yea i was trying to search and nothing came up by that first posted name, lol trying again
maybe i should reword first post. i mean what type of crank pulley to bypass the water pump as i am going electric. thanks
I would think just a single groove crank pulley. Still have to maintain the alignment with the alternator pulley if it's in the stock location. 440 source has them new if you can't find a used one.
I used the 440 source single groove crank pully I run a cvr electric water pump and a regular alternator bracket from 440 source to mount my 140 amp denso
