I'm curious if you feel there are any other drawbacks to a direct charge wire other than rendering the ammeter ineffective. I was doing the direct charge upon recommendations I found on here but now I'm finding some people saying that it defeats the factory wiring protections and actually could increase the risk of a wiring meltdown?
Depending on how its done, yes it defeats the fusible link.
One could add a second fusible link or a 'maxifuse' and regain some of the protection.
The fusible link provides some protection against the battery getting shorted to ground.
For example, if your buddy was helping while tightening the nut on the alternator's terminal accidently touched the wrench to the bracket.
First there would be sparks. Then he panics leaves wrench there while running to get help. Instead of the 12 gage wires all getting fried (and every connection in the line), the 16 gage fusible link wire melts in a relatively safe location of the engine bay.
With a direct wire added from the battery to the alternator, there are two paths for the current to reach ground. With a fusible link in both lines, it will probably burn the direct line first as its the shortest distance, and then the original path second.
There have been people here who have had bad ammeters. Or more precisely, ammeters that seemed to go bad causing a break or poor connection in the circuit. Redfish posted that he had observed early 70s models in particular had windshield leaks in that corner causing electrical corrosion. I suspect another contributor to failures is using the alternator to charge very dead batteries. Probably happens more when cars aren't driven as often.
If the ammeter posts are loose, its problem or will be. Otherwise I think the whole thing is Chicken Little.
1973 has some crazy circuit paths. We've had at least two guys here with the reverse light wires grounding onto the transmission and taking out the fuse for four seemingly unrelated items. I think '73 also has the 'engine connector'. According to Redfish it was there to make it easier for engine installation at the factory. But it adds another connection to the ignition and other critical circuits.
I've also already installed headlight relays with the Toyota kit although I now understand that they need to be powered direct from the alternator rather than the battery.
I have the kit myself, but I haven't installed it yet. The harness is going in my '85 Grand Wagoneer. Same headlight circuit as A-bodies but slightly heavier wires. Yes the shortest distance is direct from the alternator.
If you are keeping the direct wire from the alternator to the battery positive, it doesn't matter as much where the power is drawn from. But if returning to the factory wiring concept, then yes power it from the alternator. Modern cars are generally direct wired to the battery, but even in old cars the accepted terminology for system power is 'battery' and '12 volts'.
I probably should have begun with this. Instead of asking anyone to believe someone else, lets jsut explain what's going on. Then you can decide what makes sense.
The alternator creates power at roughly 14 Volts.
The battery stores energy at roughly 12.5 Volts.
In the car they are both connected together. One comparison is a water pump and a storage tank connected together. If we have 14 psi at the pump, water will flow from it before any water flows from the 12 psi storage tank unles there is some strange path or a restriction to flow from the pump.
When a drawing says 12 V or Battery it usually means system power, which can be from either Battery (12.8 Volts or less) or Alternator (13.8-13.9 Volts.)
Guys that have a direct wire and the ammeter report that the ammeter shows discharge for starting etc pretty much like normal. But the ammeter doesn't show charging. So the charging path is shorter, and the electrons bypass the ammeter. But for normal battery functions, the path through the ammeter is shorter.
The initial research I had done said the bypass would cut the current carried thru the bulkhead connector in half which seemed like a good idea and I found no mentioned drawbacks except for the ammeter no longer functioning.
Unfortunately those guys didn't tell the full story.
Sometimes they even make the big mistak eof claiming all of the cars power goes through the ammeter.
The ammeter only shows battery charging and discharging. Electrons only flow through it when the battery is discharging (start up and emergency power) and when the battery is recharging. The car's power comes from the alternator, and car ammeters do not show alternator output. (Even though its common to say alternator charging - the phrase really makes no sense).
Using orange arrows to represent flow. Engine running, stepping on the brakes, battery fully charged.
Ammeter does nothing. It just maintains the connection to the battery.
If the alternator stops working properly, the ammeter will show the battery discharging as it takes over supplying power.
