Moparmaniac40
Terry Allen
I am having trouble identifying the Aluminum case and tailstock of a trans I picked up a few years ago.I don't think it is an overdrive case as it had a 307 front bearing.The trans has 18 spline input, with Liberty gears which are in poor condition.The very front of the main shaft , where the needle bearings ride is destroyed.I have since purchased a complete Hemi 2.66 gearset and mainshaft,.The only numbers on the case are E-2801176. The front Bearing retainer is 3.70 bolt circle with 4.35 OD( PN 2538197).The case has a metal sleeve at the front Cluster Gear Shaft hole but no sleeve at the rear hole.Also have an Aluminum tailstock with no identifying numbers or Markings.The side cover is Steel with Number C95664 and below that 11X30.
I have included some pics , hoping someone can help identify the parts.
I plan to use this behind a 500 HP W2 340,in a 72 Street/Strip Scamp.
Should I just go with the Passon Case and Tailstock?
