Aluminum Door Panel Help..
Mopar Interiors
  1. cluecas
    cluecas Member
    11
    1
    Apr 26, 2019
    Denver
    Local Time:
    3:18 AM
    I'm having a hard time finding used or aftermarket door panels for my '66 Valiant. I also don't have the original door panels to work with. I'm thinking of going a different route with some aluminum Door panels. Any advice if I choose to go this route?
  2. Cope
    Cope Fusing with fire
    3,213
    3281
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    4:18 AM
    Yeah call me........
    :lol:
    I do custom aluminum interior
    Honestly tho I'm kinda backed up with work right now but if you want I can walk you through how to make aluminum door panels.
    If you just want simple, no beadrolling. you could do it your self with hand tools.
    It wont be as perfect as using the big shear or super fancy but it can be done. (Lots of the small panels I make are not square anyways so the shear dont help much.)
  3. cluecas
    cluecas Member
    11
    1
    Apr 26, 2019
    Denver
    Local Time:
    3:18 AM
    Thanks for all the pictures! That really helps get the mind going. I wasn't thinking anything complicated. Just a flat panel cut to the shape of the original panels and using the factory mounting points. Any advice you have would be amazing.
  4. Matts440
    Matts440 FABO Gold Member FABO Gold Member
    1,967
    799
    Apr 11, 2014
    Riverside, CA
    Local Time:
    4:18 AM
    Can measure you door and metalsdepot.com can cut aluminum panel for you, can do custom sizes, good prices. Have ordered all sorts of pieces from them. Copes work is bad ass though.
    • Agree Agree x 1
    • cluecas
      cluecas Member
      11
      1
      Apr 26, 2019
      Denver
      Local Time:
      3:18 AM
      He does do awesome work. I've thought about this, but I may try it on my own because of angles and curves. Thanks for the suggestion!
    • Matts440
      1,967
      799
      Apr 11, 2014
      Riverside, CA
      Local Time:
      4:18 AM
      No problem, they also offer different thicknesses
