Aluminum valve cover option when running MSD cap-adapt?
I guess 1st shift is starting early today : /
Oh well, it all pays the same : D
I attached q few pictures of the sealing surface of my Mancini covers. You will norice the void I filled with now shrunken JB weld. I added some pictures of ancient and somewhat ancient Indy covers for comparison. Neither one of the Indy covers I have is even close to flat. I'll fly cut them prior to use.
Those covers with the spray bars are a must for a 12 sec ride. :D
Get enough clearance?
Sure do : D
In conclusion:
Low deck + RB MSD w/ cap adapt + b block adapter + aftermarket valve cover = no go
Everything is buttoned and almost ready for apre-flight inspection : D
Thanks for all of the valuable insight and advice on subject.
Thank you. I sure hope it doesnt leak.
I'm almost done ptepping for subframe connectors. Hopefully that project will commence later next week. I have to travel for work this week : / I also have some customer jobs stacking up so those take priority. Lastly we are on the list to get an 8-pt CM roll bar installed in 6 weeks or so. : D
My apologies to the resto crowd on that.
Check out my new to me front wheels --->
