Attached is a picture that represents what the diff cover looks like on the one under my 68. I think it's an AMC 20. When looking at the specs I found that the spring perches were only 1/2 inch wider..1/4"/side....and that the width was right there too. The yoke takes a different size U joint but cant remember how far off...+.050 rings a bell...
Anybody seen this rear end under an A body????might be a common swap???
I'm a gonna drop an 8.75, 323 suregrip in there in a couple of weeks and I'm wondering what the difference in length the axle centerline is from the yoke U joint saddles between the AMC 20 and the 8.75. I'll probably have to change the driveshaft yoke to match the 7290 pinion yoke on the 8.75????
I just wonder if the drive line length and existing yoke and other mounting hardware and brackets will work without modification. The 8.75 is out of my long gone stock totaled 68 Barracuda.
