AMD 67-69 Barracuda quarter install
FM3 Dart
Here are a few pictures of a 69 Barracuda that I installed new AMD full quarters on. Also installed AMD trunk floor extensions and rear valance. Could not be happier with the quality and fit of these panels. Absolutely beautiful panels. The quarters almost installed themselves. No body filler needed, except at the factory roof and rocker joints.
Quite possibly the best quarter panels I have ever installed.
My body guy said the same thing. Unfortunately, my project stalled at stage two.
You guys are lucky! I had to chop the hell out of mine. But otherwise it fit very well. I have to do the other side still, and also have the valance. Definitely awesome parts
That look very familiar! My quarters are straight and nice now! Never knew there was that little body line on the the lower edge that follows the door till the new ones were installed. Looks great!
Great thread, thanks. I am very likely going to purchase this 68 tomorrow and will be going down the same path. It is supposed to be a dry rust free car. I will keep you posted.
As a matter of fact, the AMD torsion bar crossmember, inner fenders and floor fit pretty well too. Of course some persuasion is necessary from time to time
Looks awesome! I used goodmark because I just needed to do a lower patch and it was a pain.
Couple questions for you. The factory has the back lip of the quarter where it meets the rear valance flanged inward with the valance laying on the outside of it. Did they come flanged like that or did you flange them yourself or did you just overlap the valance without flanging?
Also is that B5 blue? Looks great!
You do awesome work, Ken.
Thanks for posting this!
Those cars look great in B7............
It is B7 Jamaica Blue Poly. Yes, there is a flange for the valance to fit flush.
They come flanged
I should have just paid the money for AMD. I wasn't able to flange the goodmark and had to just weld it up smooth in the back to keep it from looking goofy.
Color looks great and apparently I'm colorblind to boot :realcrazy:
Then a notchback panel should work?
Mine was a fastback panel I had to cut. Don’t think AMD makes one for our cars. I placed a piece of 1.5” painters tape on the body line on both. You need to cut the window fur part off of the AMD one and then anything to the back until which point you see the fastback truck lid curve. I chose to keep as much of the new panel as possible. When I get back to the shop tomorrow I can take picture of the passenger side I am currently working on. There is another thread I will link to, where the guy uses the goodmark panels on a vert. I used the ideas from there for mine. Again... Thanks guys
