Question: Has anyone installed the American Powertrain #HMCH01101G Hyd throwout bearing kit? Specifically, do you have a Centerforce II diaphragm clutch? Was it straight forward in ease for installation? Accurate installation instructions?
Did the mstr cyl fit or did you have to alter the inner fender well?
Is there a mstr cyl brace?
Does it work as advertised?
Easy to push pedal down?
I am put off by the price, I could probably piece something together for less money, but would bite the bullet if this kit will do the job. I have an issue with my left leg from two hernia surgerys, I need an easier way to push the clutch in. The diaphragm clutches benefits are cancelled out when the overcenter spring is removed, and I am tired of fighting the linkage fix bandaids.
