American Powertrain Transmission crossmember for mounting a TKO-600 in an a-body. Like new, never installed. Fix the tunnel to accommodate the transmission, and this replaces the original crossmember. The large ends slip over the rearward end of the Torsion Bar mount, and once bolted in is very rigid. My 73 Duster ran a 425 hp stroker with a TKO600 and an identical crossmember and had no flex or problems at all, even under the most spirited launches Powdercoated black, no scratches, like new! Runs $349 from American Powertrain, get this one for $165 shipped to the lower 48.
