Watching also. Good luck and hope you feel better soon!
The lifters are Johnson HyLift non MDS hydraulic rollers.
I can only go by the boxes they came in as there is nothing on them to id them. All the boxes had the correct info for Johnson.Are those the eBay ones? If so, how do you know they are Johnson's?
Pretty sure you won't have a choice but to use a custome piston with this setup.I have a Hellcat crank and rods. Because the rods have a bigger pin end than a standard 5.7 rod, I am having a bit of a hard time finding pistons. I want to keep the compression in between 8 to 1 and 9 to 1 if possible. Does anybody have any ideas on a set of pistons? Trying to do this on a budget so I am hoping to avoid custom slugs.
Jack
Jack
Looking forward to seeing this build. I was SERIOUSLY contemplating a roots style blower. Keep us posted as I will be following.I have officially started my 5.7L blown stroker build. All future posts as to my progress will be posted here. I have the 2010 5.7 truck engine mounted on the engine stand and disassembly will start as soon as the bitter cold leaves. I still have to build a couple of shelves in the garage to hold the used parts I will be taking off the engine. This will be a complete tear down as it will be getting new forged internals to handle the boost from my 6-71 Dyers blower. This will be a big job but should end up with a real nice setup. Here are a couple of start photos. Yes I know, the garage is a mess right now. I also know that this is going to take a while.
Jack
