Another episode of " Name This Part "
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
Hey guys and girls ! I have a couple things I would like to figure out what the heck they are !
First up is
#1
Small Block Mopar Real Race stuff .
Header flanges..
Up #2
I know for SB , But I cant find it anywhere one the NET !
Up #3
What the heck are these from ?
and #4
Maybe from a duster ?
Thanks for any and all Help !
The bottom header flange look like W2. Not sure about top one.
Cam thrust plate with bearing. Haven't seen those available for a long time.
#4 maybe a seatbelt retractor cover but that's just a guess.
It's been a long time so I might not get this 100% right but it goes something like this.... The top & bottom flanges go together... The top flanges bolt to the race head which has the bolt holes relocated to allow head porters to go nuts... The lower flanges bolt to the first set of plates allowing standard headers to be adapted the the race head....
What Mopar Head ? Is W2s - W5s & W9s all the same exhaust holes ?
Top plates are 4 bolt Hooker header flanges to weld the tubes onto when making headers. You need the adapters for Hooker headers to use them . Once the headers are made you cut them apart
The bottom plates are W2 Hedman header adapters plates that bolt on the head and then your headers bolt to them.
I would be interested in them if the price is right to make patterns out of stainless
Believe this correct, as years back, had both Hooker & Hedman W-2 headers.
#2 may be a Hamburger torrington cam plate for a small block, and the aluminum spacer may be the spacer used for cam bolt and cupped washer without fuel pump eccentric.
