Dizzydean
Good Day, well here is another 1. I had a problem with the temp/fuel gauge pegging to the right when the ign was turned on.When I turned on the headlights or the turn signal they went back down so I replaced the regulator with the new type internals. Temp didnt move & the fuel barely. Thinking the part was bad I did the 7805 mod and put it all together,same thing. Fueled the car up and the fuel gauge went 3/4. So I figured I removed the new regulator for nothing cause now I now the sending unit is off but still no movement from the temp and I know the car runs hot. Any ideas???
