Valiant72
Okay, my frustration level is higher than my temp gauge! Replaced my six with a 360 out of a Newport which I drove and ran cool. Now it goes to 220 at idle. I replaced the water pump, radiator (22 inch), thermostat and hoses and no luck. Will run at 180 deg. at 55 mph fine. The fan blade's closets point is 2 1/8 inches from the radiator, is that to far? I have a Duster and it's only 1 1/8 inches. From what I've read from past threads there should be no problem using the stock radiator. Timing set at 10 BTC and tried a different gauge. Any help appreciated.
