moffetkustoms
Wanted to share a work-around that I used on the wiring harness of the Scamp! Doing a complete wiring harness change and wanted to bypass the factory firewall plug connectors. Found this print program online and used it to 3D print a clean box to cover the factory hole in the firewall and run my wiring through. The bottom flat surface prints with 2- 1/2" holes that I opened up to be one long oval. The wiring will go up in the opening and be covered in loom. The loom will then be slid up into the box and that will finish off the firewall side. I'll close off the box from the inside then to keep dust, fumes out of the passenger compartment.
