I am in the process of swapping my electric stove out to a NG unit. With that said I want to reroute the 220V line over to the corner of the house, install a junction box and then run wire in conduit along with a gas line to my garage. This will be about a 50ft run.
What wire should I be looking at to run in the conduit?
I will be installing a small breaker box in the garage to run my air compressor, and some lighting along with small electric tools ie: drills, parts washer etc.
If you could be as specific as possible about the wire I would be most grateful. I may run it and then have an electrician do the hookup, not sure yet. I have worked with this stuff over the years but don't yet totally understand the wire requirements. (as in which type, gauge etc)
Thanks in advance for any help.
