Any pics of a 73 duster with hood pins?
Here ya go.....pay no attention to the laundry in the background! LOL!!
I had trouble with where i drilled the holes, the surface was not flat and I had to use a spacer on one side of the washer to get the pin to set flat, Walt
I'd be interested to see where they are mounted under the hood and also if any body has a lift off hood where you mounted the pins for the rear
Thanks,Bob
I dunno if this is gonna help or not... but look at the top of the pic, you can see the pins for the driver's side.
And this one you can see the passenger's side one:
