richierichpoky
Has anyone had any luck with doing their own?? Are there any posts or how too's on doing this??
I used greased lightening cleaner. Or you can do glass bead blasting. I had a Pro straighten and polish everything.What did you use to strip them?? any info on taking dings out would be great. Mine are pretty banged up
If you look in my 2nd post you can see before pics. Mine were about that good too.
"Patience" being the key word here.
If you want to try it yourself use every little tool you can find to get the right curves you need.
I have used washers rounded on the edges, small pieces of hardwood, cut down drill shafts and about every other thing you can think of.
Using a hardwood backing surface works good for supporting your metal without ruining the area around your ding.
Then file and sand to get the small imperfections out.
I see Leanna posted before I did.
Yeah Ya never know. I'm going to try doing it myselfMine are exactly the same condition...Might do some reading and have a go...doubt Ill find any spares in Australia
