............i would try the pick up in the dist...........kim.......
By try it do you mean try replacing it same as replacing the ECU box?
Didn't read the whole thread but here ya go.
timing is moving around so its one of three things
1. Light Dist. springs not holding the weights at idle
2. Timing chain bad
3. short in ignition somewhere
It's the simplest vacuum check there is. Just try to draw air through the tube. You either can or can't.we'll put this on the list of items / places to check. Thanks!
Was the distributor or box underwater?
Stuck lifter? Do they all have free movement when bled down?
My 2 cents... 10 degrees is not enough initial, get it into the 16-18 range.
What is the idle speed? I wouldn't want less than 800 rpm.
What is the idle vacuum, should be in the 12-14 range with a XE268H, higher end with more initial. Adjust the idle mix screws using the gauge as a guide.
That sounds like it may be dripping fuel in from the carb boosters.
What first jumped out at me was the fuel filter being on the suction side of a mechanical pump.
Maybe?
That would be a problem with a mech pump , something to check . Always mount the filter after the mech pump , at least that's what I was taught , air in the filter with a relatively weak mech pump can cause the stumbleWhat first jumped out at me was the fuel filter being on the suction side of a mechanical pump.
Maybe?
Rick,
As I am in the process of learning I was reading throught this thread. Idling is of course an issue I have as well. I do not have the bucking as this member has. But I am interested in why you have concenrn for the position of the filter?
Do you have a theory?
maybe it jumped a tooth. may sound dumb but, have you verified the firing order and is it clockwise rotation on the cap.
...do you have the plug wires off in the correct order? Maybe one got placed a plug off?
its not a fuel filter issue. Reason this is ruled out is that we have a fuel gauge right on the fuel rail to the carb and it is hold at 5.5-6.5 psi at all times which is what the pump should be. So there is no spike or dip in the fuel pressure corresponding with the bucking of the motor...
Okay so here is what we did tonight and nothing solved the bucking issue:
swapped out all of the following and individually tested (ecu box, distributor, coil, carb) All swapped items were good and working prior to swapping. The bucking still persisted.
Couple items to note:
The engine smooths out above 1400-1500 rpm or anytime we get on the throttle. Bucking only shows up at idle.
Vacuum gauge with carb on the motor bounces a lot between 12-14. Did a carb swap and it held vacuum more stable but not nearly as high. With either carb when we deliberately uncapped the vacuum creating a leak it runs better with a little less bucking but does still bucks some.
Timing we have tried everything all over the from 14-17 initial to higher around 20-24 and both are about the same nor do they eliminate the bucking.
So out of ideas we did a compression leak test on all of the cylinders and they are all within 150 - 155 - 160 range and hold. While doing this read read the plugs and they are definitely reading rich
Then we pulled the valve covers and cycled the engine a few time to visually verify that the valve tran was all moving - Yes it is......
At this point both point both Mopar Al and myself are out of ideas..... We are open to any thoughts that we have not already tried....
trust me have tried a lot... 4 carbs, 2 dist, 2 coil, 2 ecu's, 3 fuel pumps... compression test, timing, vacuum gauge....
