yellowghost
I am trying to re-install my control arms, but it seams the pivot shaft nuts are a locking type. So no way I can turn them finger tight as my manual suggests. I cannot even torque them in without the pivot shaft turning in the bushing. Should I switch to a non locking nut, with a locking washer? I am using the poly bushings. I got them in a set so I figured I might as well use them. Them inner shell is tight in the bushing, but I can twist the shaft right out of that shell. Do you have that problem with regular rubber bushings? I think I do have to change that nut regardless, because tightening it finger tight only still leaves a quarter inch gap between the washer and the frame. Not sure I want to lower the vehicle like that.
Thanks
Jeff
Thanks
Jeff
