Following refers to RH drive: on rh side of heater core in passenger footwell there is a a plastic arm which should have a threaded rod attached to it, when you change the climate control slide on dash the rod will move the arm that controls the air flow, this rod can become disconnected......
For RH drive...but you get the picture. Maybe this will help.
