C cooooledart Well-Known Member Joined Jun 3, 2015 Messages 47 Reaction score 0 Location California Aug 25, 2015 #1 How do you remove this from the end of the rod? And what is the correct term for the rod? Thank you Attachments 20150825_180436.jpg 66 KB · Views: 184
ssba Well-Known Member Joined Dec 29, 2009 Messages 2,271 Reaction score 286 Location rensselaer in Aug 25, 2015 #2 Clamp the pushrod in a vice and pry the piston off with a couple prybars or screwdrivers. Leverage is key.
zkx14 Duster De-ruster FABO Gold Member Joined Dec 23, 2012 Messages 34,302 Reaction score 38,841 Location South Central PA Aug 25, 2015 #3 Master cyl push rod. It 'pops' out. Best to do while all still in car. Should be able to grab in a vice and get a fork over the part that goes in MC. Tap wit hammer.
zkx14 Duster De-ruster FABO Gold Member Joined Dec 23, 2012 Messages 34,302 Reaction score 38,841 Location South Central PA Aug 25, 2015 #4 A little lube in the hole might help. Silicone spray? Its just a little rubber piece in there.
