Anybody run a SB Edelbrock Perf RPM cam?
crackedback
Namely looking for input on the 7177 grind.
234/244 at .050
.488/.510
112 LSA
Thanks
a fríend of mine used to run the performer rpm cam in his 383 chevy, ran very well untill he lost a lobe.... dont know anyone how have used that cam in a mopar
234/244 at .050
.488/.510
112 LSA
Thanks
Rob,
What compression and details on the heads?
Buddy of mine ran that for a while and it was "ok", but he was running 11:5:1 compression and J heads.
-Justin
Rob,
-Justin
Was interested in Idle quality. I spoke with someone and they said it was really dirty compared to an XE274H. Got told run the 274 or a 275HL instead and the guy wasn't even selling me anything. Said it's a slow lobe as it's adv 308/318 duration. Don't know lift point on that.
Was thinking about putting it in a 360, 11:1, ported J heads, RPM intake 750, 3500 converter, 3.91's
Ran one in a low compression 400. Didnt make power till around 3000rpms, idle was pretty rough. Surprising because its on a 112lsa.
I haven't ran one but looking at the specs it does look kinda lazy in comparison to the Comp XE or Lunati cams. With that much total duration it'll have a bunch of overlap so probably won't idle great. I once ran a cam in a 360 that was pretty equal in ramp speed but slightly less duration and lift. It didn't pull good under 3000 and idled pretty rough but it was decent on upper rpm to about 6500
