Anybody running 18" Bullitt rims on an A Body?
Greg55_99
If you're running 18" Bullitt rims on an A Body, can you post pics and details?
Greg
How about 17's on a 65 Cuda.. I'm running 275 40R17 on the rear and specs are 24mm with a 5.95 back space. On the front I have 225 45 17's. Rear rims are 17 X 9, and front 17 X 8. I bought them from American muscle, they are a Mustang place but they had the wheels that fit. I'm running an 8 3/4 rear with Yukon axles with wildwood disc brakes and green wheel bearings. My car is not mini tubbed but does have the springs moved into the frame.
Best pic I have, with the wheels on and the car on the ground before I ripped it all apart to repair floor and put on frame connectors.
I'm running eighteen's will upload some pictures for you. I have a couple in the 8.8 rear end thread. I'm running 245/45/18 on mustang rims.
Rear end Ford 8.8 disk brakes standard length. Rear Springs moved in 1/2 no other mods.
Front end 18" wheels sometimes work better because of issues with tie rod end clearance. There is a long thread in wheels and tire that goes into depth about it.
View attachment 1714989717 I'm running eighteen's will upload some pictures for you. I have a couple in the 8.8 rear end thread. I'm running 245/45/18 on mustang rims.
These r what I decided on. 17" x 8" on the rear with NX3000 245/45ZR17 and on the front I put 17" x 7" with N3000 215/50ZR17 tires They fill the opening very nice with the stock spring location. I did change out the rear axles to get the larger bolt pattern and also did the discs up front with the 2.5" heavy duty shoes in the rear. I also installed new super stock springs which gives a little higher ride height in the back. I like how it sits. Sorry, this is the best picture I have so far.
I'm hoping to see the 18" wheels. I'd like to know if any mods are required to run them and what tire sizes work best.
Not bullits, but they're 18 x 8.75 with 255-40 tires rear and 245-40 front. Backspace is 6.25" and offset is +35.
Drum brake spindles with AR Engineering 1st gen Viper caliper kit, and a '69 B-body rear end make it all work with no spacers, no cutting, and no rubs.
However, since it is lowered, I needed to carefully massage the inner rear wheel well protuberance with a big-*** peen.
