anyone ever install a rear tail panel decal?
I've installed lots of decals over the years. The best tip I can give you is use lots of soapy water(dishwashing detergent). It will let you move the decal around and get it in the right location before it sticks. Work the water and air bubbles out with a squgee and you should be fine. You can use a heat gun or a hair dryer to help the decal contour to any curves and help remove air bubbles. Letting if sit in the sun will remove air bubbles as well, also you could use a pin to poke a hole in any air bubbles. Working in a restoration shop, I installed decals all the time, including numeruos sets of billboard decals and I did them all this way.
