Hello, I currently hold two U.S. Utility Patents and a Registered Trademark. It's quite a long and expensive process. The first thing I would recommend you do is to get a great patent attorney. I could help you with this. The first part of the patent process will be a thorough patent search done by your attorney to see if anything exhists like what your trying to patent. Then, If patentable, your attorney will guide you from there because there are several kinds of patents. I hold Utility Patents. I will be leaving out of the office now, but I will check back later tonight with you.
