You've got a couple different things going on there, so I need to clarify a few things.I have a 1973 340 block fresh build i bought and my car has heater box delete and i dont need the extra hose fitting i want to cap all 4 off does anyone know the sizes? Refer to photo
1 and 4 are 5/8" OD. can be plugged with a 3/8" npt plug i believe.I have a 1973 340 block fresh build i bought and my car has heater box delete and i dont need the extra hose fitting i want to cap all 4 off does anyone know the sizes? Refer to photo
The two on the right (2 and 3) are for coolant recirculation don't cap those.
The manifold (4) is either a 1/4 or 3/8 pipe thread.
You can tap the fitting on the water pump (1) with a 1/4 pipe tap and use a plug. Pretty sure it's 1/4. Could be 3/8. I did it once.
Get a pipe plug assortment and a couple taps.
Very helpful thank you I actually am going to replace water pump with proper one for 71 demons the radiator port is on passenger side for demon radiator and i notice new polished aluminum pump doesnt have the fittings so was wandering how to keep it all nice and clean. As for the 73 block, the crankshaft and crank internals are 1969You've got a couple different things going on there, so I need to clarify a few things.
First, you've got the early (pre-'70) cast iron, driver's side inlet water pump, which uses a 3/4" bypass hose fitting (2). It's hard to tell in the photo because of the tape and everything, but it looks like you've got a later factory or aftermarket manifold that uses a 1" bypass hose fitting (3), possibly the factory '73 manifold?(Edit: Nope, I can see "Edelbrock" on it now that I'm on a laptop) If so, you need to replace it with a reducer and fitting to the appropriate 3/4" size for your water pump and run an early bypass hose.
The early water pump uses fittings for 1/2" heater hose (1). Early (pre-'70 factory, and early aftermarket) manifolds also used fittings for 1/2" heater hose (4). Later factory and current aftermarket manifolds use a fitting for 5/8"heater hose.
Now the good news. The early water pump had thread-in heater hose fittings that can be removed and replaced with (If I recall correctly) a 1/4" pipe plug. The manifold fitting can be removed and replaced with either a 1/4 or 3/8 pipe plug, depending if it's an early or late manifold.
You really should run a bypass hose on a street engine, but a strip only engine can have the nipples removed and plugged.
Edit: Just to be clear, heater hose sizes do not equal fitting sizes; i.e. a 1/2" heater hose generally takes a fitting with 1/4" pipe thread, 5/8" hose uses a fitting with 3/8" pipe thread, etc., although adapter fittings can be found in virtually limitless combinations. I referenced the factory sizes.
Also, on an unrelated note, if that is a '73 motor, it would have originally have had an externally balanced cast crankshaft, and the balancer shown in the picture is for an internally balanced forged crank. Hopefully this means that during your rebuild, the cast crank and balancer were replaced with a forged unit and it's balancer, or at least was rebalanced with the new parts. Factory '73 340s are picky, because they require one-year only parts like convertors and flywheels...
And hopefully that balancer has had it's timing mark properly re-indexed for the passenger side timing tab.
I guess you don't like using the agree button for a poster.I agree. Don't cap the water pump bypass. It's not a great idea.
If you change the water pump, you will also need to change the timing cover to the later style so you'll have the timing marks on the driver's side where you can see them ( the WP inlet will cover them with a mismatched setup). Then you will have to make sure the balancer has it's timing marks located correctly for the different timing cover marks.Very helpful thank you I actually am going to replace water pump with proper one for 71 demons the radiator port is on passenger side for demon radiator and i notice new polished aluminum pump doesnt have the fittings so was wandering how to keep it all nice and clean. As for the 73 block, the crankshaft and crank internals are 1969
Damn i didnt know all that maybe i will just get a different radiator lol that sounds like the easier option and least impactfulIf you change the water pump, you will also need to change the timing cover to the later style so you'll have the timing marks on the driver's side where you can see them ( the WP inlet will cover them with a mismatched setup). Then you will have to make sure the balancer has it's timing marks located correctly for the different timing cover marks.
I am not familiar with the brand of water pump you're looking at, but it appears to have threaded ports that can have MPT plugs screwed into them. Again, don't plug the bypass port- get the correct size fitting and use it.
Would my current setup with driver side hose cause any issues with anything other than just changing to a driver side radiator i dont have a radiator yet so thats no sweatIf you change the water pump, you will also need to change the timing cover to the later style so you'll have the timing marks on the driver's side where you can see them ( the WP inlet will cover them with a mismatched setup). Then you will have to make sure the balancer has it's timing marks located correctly for the different timing cover marks.
I guess what im saying is dors the 1969 dart driver side radiator mount the same ast the 71 just different outlets because i have all the 69 parts for motor and changing cranks and all that aint happeninDepends on what you have for accessory drives- if you have power steering, each pump style takes a different set of brackets and power steering pump. Same goes for the alternator- slightly different brackets. And then, since the later water pump is deeper than the early iron pump, the pulleys and offsets are slightly different. Go with whatever water pump you have the most parts for.
1971 Dodge DemonWhat year is the car? A-body I presume?
Ok perfect so 1969 radiator hoses and 1969 radiator with the 1969 water pump got it.If you use all '69 parts, it will fit in a '71. You can't mix and match with '71 parts though. use a set from one or the other.
