No. It's steel. With a bevel on one sideurethane? cut down shackle bushing...but not with the angle...
I thought about the same thing but the center hole is almost 3/4"thought bushing for clutch linkage rod to fork but that would be 3/8" I.D. or there about. and,thank-you, bevel, not angle
I'm stumped alsoI'm out but will keep watching. Did the PO put it in the parts box to throw you off? maybe it's from a project he's still working on? One more wild guess: it's from a snow blower.
Thank you very much!. This car did have air shocks on it before. Makes sense.on vehicles with air shocks, it was necessary to move the top of the rear shock away from the body mounting location because the top of the shock is fatter than stock, so this goes on the mount shaft between the rubber bushing and the body. Since this means that the shock mount stud does not have as many threads sticking out of the rubber bushing, there is a companion threaded piece on the outside of the bushing that replaces the stock conical washer and nut.
