I just purchased a brand new mopar distributer from Don at FBO systems and i noticed it is not the same style that my older mopar distributer is... The insides are different and the adjustable mechanical advance mechanisim is different. Is mopar selling a different style distributer these days?
Anyways he curved and phased it according to my engine and gears and i must say my engine is running pretty darn good... He told me i had to run the vaccume advance off of manifold vaccume and i followed his instructions and took it out for a drive and it is running really good.
The only complaint i have about this distributer is that the distributer cap does not fit snug onto the distributer... The wires coming out of the distributer pick up assembly sits too high on the distributer and the cap hits the liitle rubber mount piece that brings the wires from inside the distributer to the outside of it. I'm just wondering if anybody here has also ran into this exact same problem with one of his new distributers for a small block mopar and if so what did you do to get the cap snug onto it? If no body has had this same issue then what do you recomend doing?
I was thinking off cutting the rubber down with my pocket knife... Not deep enough to hit the wires but just enough off of it to make the cap more snug onto the distributer.
I still have my older mopar performance distributer wich has the mallory style adjustable mechanical advance, but once i started changing spring combo's i could not get it to run right and got frustrated with it and bought aa new one from don at FBO thinking i would get the same style distributer... I'm going to buy a new pick up assembly and reluctor and vaccume advance can and put it on my older mopar distributer and i'm going to box it up and send it to don at FBO systems and have him custom curve and phase it on his distributer machine and send it back to me.
I probly should have done this the first time, if i would have known the distributers he sells were different then thats what i would have done... I just figured the mopar performance distributers were still the same style as the older one i have wich has the adjustable mechanical advance with torx screws. But for 89 bucks i can send him my older mopar distributer with the mallory guts and have him set it up on his distributer machine and send it back to me, i will have 2 basucally brand new distributers but it ccant hurt to have a back up distributer i guess.
