Looking to swap out current comp. XE 268h
To this,
Lunati 740 specs
Adv. 264 / 272
.050 235 / 243
.526 / .546 lift w / 1.5r
110* LSA
Engine,
340 .030
Stock stroke
Srp flat tops 10.5
Trick Flow heads
1.6 roller rockers
Air gap
670 or 750 carb.
Doug's headers
2.5 exhaust out the back.
2100 stall converter
This is a daily driver on 91 pump gas
Looking for more power all around
Plus the Comp is a click small for 10.5
I can only put 30* total timing before it pings..
Plus the Comp is Noisy for a hydraulic
And not real crazy about hydraulic lifters these days..
I figure if it's gonna tick n tack at least it should make more power...lol
Has or does anyone run this cam?
To this,
Lunati 740 specs
Adv. 264 / 272
.050 235 / 243
110* LSA
Engine,
340 .030
Stock stroke
Srp flat tops 10.5
Trick Flow heads
1.6 roller rockers
Air gap
670 or 750 carb.
Doug's headers
