Are 10 inch spindles identical side to side?
furyus2
weeki wachee fl
So, I'm getting ready to align my front end on my 69 340 Swinger. Looking at the spindles, are they able to be swapped side to side? If not, how do I identify?
To answer why I'm asking, looking at the spindle from the wheel well, it looks like the top of the spindle leans slightly forward, when I am sure it's supposed to lean back at the top for caster??
Nope
Be careful of which bolt you screw in. It has a longer thread or I should say has a shorter shoulder. The wrong bolt won't clamp it all together as the shoulder will hit the threaded part. 100 lbs on the lock nuts for the bj.
Just wanted to say thanks for all the help.
I did find proof on the Summit website that the threaded hole goes to the rear. Also, the rear bolt holes on the spindles are further apart.
Most times in parts if it ends in an odd number, it's left and an even number is right. At least for Mopar and Ford, I can't speak for GM or foreign cars.
