Rapid Robert
63 dart 360 2bbl 904 8&3/4. 235/75/15 street tires. 3/8 mile high banked ruff dirt track. hobby stock class (street stock). 6K rev limiter. thank you for your time. RR
My 49 Ford 8N tractor has 6.66 gears. It's goin to hell. lolMaybe not. When modified raced cedarburg where I grew up, they raced 6:66 0n 1/4 mile clay.
spicerparts.com
I sent you the gear chart for the class you're running in and the tracks near you in Nebraska. It has gear recommendations for open and crate options. If it's not on the chart tell me which track you need the gear recommendation for and I'll find it for you. If you didn't look at it here it is again. Why are running a 6k rev limiter? Your rules allow 7000 RPM on an open motor.63 dart 360 2bbl 904 8&3/4. 235/75/15 street tires. 3/8 mile high banked ruff dirt track. hobby stock class (street stock). 6K rev limiter. thank you for your time. RR
Which track are you racing at?92b yes I saw the chart, thank you very much & it tells me that my 5:57's will be just fine which was surprising. & I reread the rules & you are correct my motor can use a 7K rev limiter
Eagle takes a 6.50 or a 6.66 gear for an open motor. You want to run a 5.57?eagle nebraska
