Are the 360 magnum heads the same as those found on 318?
19dart71
NC
Are the 360 magnum heads the same as those found on 318 magnums? I found some from a 360 but want to make sure they would also fit on my 318. Are they the same?
I'll give you the other 1%,lol!! They are absolutely the same.
Yes, they are the same, the same in ALL respects.
Including a high mortality rate due to cracking.
They crack between the valves, usually bad enough that they won't hold a steel seat ring.
Had a friend of mine recently go through NINE sets of heads to find ONE head worthy of rebuilding for a customer.
Mopar knew they were a faulty casting, but it was cheaper to warranty than re-tool, especially since a majority did make it beyond warranty mileage.
Worse, I believe some of them actually were installed on crate engines.
Mark.
My son was the service manager at the local Dodge dealer for a couple of years. They on an occasion would have to replace a head because it was cracked but certainly not a wide spread issue.
