Are the Rear end Gears the same 7 1/4?
TF360
Florida
Are the Ring and Pinion the same for the Small Bolt pattern and Big Bolt pattern 7 1/4 rears? Will a 70 SBP Ring and Pinion fit properly into a 74 with BBP rear? Thanks for ant help.
Yes, the only variation is very early-A ('60-'62(?) ) 7.25's had a different pinion spline & smaller ring gear screws IIRC. '70-'74 You're good.
