[SOLD] Assorted Ignition Parts
68 CUDA FORMULA S
Clarkston Michigan
I have some different assorted ignition parts that have been lying around since my 66 barracuda build that I do not plan on using. There are two coils 1 mopar and 1 delco remy, there is a delco remy voltage regulator, a set of points with the distributor wire and a couple of screws, a random coil wire, and a set of new small block v8 plug wires with two coil wires 1 short and 1 long, and some new Mallory plug wire boots and wire ends. $30.00 for everything you see in the pictures and I will ship everything together in a USPS medium flat rate box for $16.25-$46.25 total.
