[FOR SALE] Assorted LA topend and ignition parts
smokinnjokin
Nekoosa, WI
MOPAR LA ASSORTED PARTS FOR SALE/TRADE.
360 Magnum pie pan. $25. Looking for ‘360 4-barrel’ if you want to trade.
Dayco upper radiator hose 70975, for ’67 b-body small block. Brand new. $10
Edelbrock phenolic heat insulator, open. Has both gaskets with ears carefully cut off so they don’t overhang. Outside painted black. $SOLD
Electronic ignition LA distributor gutted core. Has no advance mechanism, plate or weights. Has been clearanced for designed2drive bracket. $10
Designed 2 Drive HEI mount bracket. Has been clearance to sit flush on underside of above distributor. $SOLD
Voltage regulators, old-style. Both work properly. Replaced with solid state. $10 ea
Small block LA intermediate oil pump/distributor drive shaft. Replaced needlessly. Has minor wear, does not effect function. $10
Standard VR125 voltage regulator new in box with new connector/adapter plug $SOLD
Vacuum advance can 4091663, pulls 14 crank degrees (as per Halifaxhops machine), arm marked 7.5. Adjustable. Has curved armature. $25
Stewart-Warner Greenline 6k tachometer. Does not include sending unit. 2-1/4 diameter. $70
I will ship items in smallest possible USPS flat rate box, we can discuss combo deals and shipping options. Everything would probably fit in a large flat rate.
Trade interests:
360 4-barrel pie pan.
Front disc brake swap components. Primarily 15/16 bore master, 4-stud mount without booster for manual disc.
Tiny pentastar logo that goes on ’67 b body below the trim
Shroud for 22” LA radiator for 67 b-body
Thanks for looking. Cross posted on FBBO.
Edelbrock phenolic heat insulator, open. Has both gaskets with ears carefully cut off so they don’t overhang. Outside painted black. $10
Standard VR125 voltage regulator new in box with new connector/adapter plug $20
Trade interests:
The standard VR-125 , is it correct voltage regulator for say a 1977 Power Wagon
