DustyDan
Member
So I recently completed my 360 build got the motor In the car (73 duster). Original motor was a 340 with cast crank. The 360 has a forged crank, I had the rotating assembly balanced. Because of that I needed a different alancer. So I went with an ATI super damper. Problem is once it's on and I put the crank pulley on none of the grooves for the alt. Or P.S. line up. The sit about a 1/2 to 3/4" back. The damper is pressed all the way on. I'm not sure why it causes the pulley to sit further forward. Is the damper wrong or do I need a different crank pulley.
