Everything works, but needs the temp sender and the speedo adapter is damaged and will need a new one. Volts, temp, oil, fuel level, electric speedo. Priced them and both are under 75 bucks. Also has a quick disconnect. Has high beam indicator, brake and turn signals. Has a small crack under the speedo, not noticeable. for Duster Demon, Dart Sport. shipped anywhere in the continental US for 525.
