Autometer pro-comp guages
clv22p
72 Dodge Demon 340
Nashville, Tennessee
Autometer pro-comp ultra lite guages. Tachometer, speedometer, fuel level, water temperature, voltmeter, and transmission temperature. The tech and speedometer have the Chrysler pentastar in the face. They are never used guages. They were mounted in a cluster, but never used. $500obo
What sizes are the gauges, mechanical or electrical? If electrical do they have senders? What OHM's for the fuel gauge?
Thanks
Riddler
The water and transmission temp gauges do have the the sending unit. The smaller guages are 2 5/8. The tach and speedo are 5in. Ill check for the OHM's on the fuel gauge.
Thanks
Riddler
They have a white light behind the faces. There are little rubber caps to put into the bulbs to change the color. Automated surplies green and red caps with there gauges.
