axles ( green bearing ) measurements
Suspension, Steering and Chassis
  1. Buschi340
    Buschi340 Well-Known Member
    1,248
    25
    Feb 19, 2005
    Wilhelmshaven, GERMANY
    Local Time:
    6:17 PM
    guys, i need advise. I need the measurements of an axle shaft for a 72 housing ( 8 3/4, 486 case but 4.5 bolt pattern ) to replace my existing axles with axles from Strange. I can't measure myself because i would have to destroy the green bearings on mine. Maybe one of you guys has notes or an axle arround? the measurement i hardly need is that Dimension B on the order form Strange is asking for. thats the bearing stop which is machined on the shoulder of the axle.
    unfortunatly i can't upload my measurements here. But guess you know the form I am asking for.
    http://www.strangeengineering.net/wp-content/uploads/2013/11/Axle-Order-Form.pdf
  2. Buschi340
    1,248
    25
    Feb 19, 2005
    Local Time:
    6:17 PM
    i can Show my measurements i made so far on Fotos of this form ...
  3. Dana67Dart
    Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
    7,859
    5466
    Jul 16, 2017
    Northern Colorado
    Local Time:
    11:17 AM
  4. Buschi340
    1,248
    25
    Feb 19, 2005
    Local Time:
    6:17 PM
    Good thought. Bit i wants strange because i order here in Germany through a Local Dealer. And they need the exact measurements
  5. Dana67Dart
    7,859
    5466
    Jul 16, 2017
    Northern Colorado
    Local Time:
    11:17 AM
    Contact Cass at Dr. Diff im bet he will have the answr for you. I have 2 loose oe a-body axels but yhth have oe bearings on them. i can get you measurements BUT i cant guarantee the accuracy
  6. Buschi340
    1,248
    25
    Feb 19, 2005
    Local Time:
    6:17 PM
    If those are for big bolt pattern it would be helpfull
  7. Dana67Dart
    7,859
    5466
    Jul 16, 2017
    Northern Colorado
    Local Time:
    11:17 AM
    Sorry I missed that, they are SBP.
  8. DoctorDiff
    DoctorDiff Well-Known Member
    319
    262
    Sep 30, 2012
    Polson, MT
    Local Time:
    11:17 AM
    B dimension on a standard, 5 x 4.5" bolt pattern Mopar axle is 2.5".
    This does NOT apply to RE-DRILLED 5 x 4" bolt pattern A-body brakes.
  9. Buschi340
    1,248
    25
    Feb 19, 2005
    Local Time:
    6:17 PM
    Thanks Cass. Really appreciated!
