1ToughDuster
As I undergo my 8 3/4 axle swap I wanted to check and see if anybody has ever put a 62-70 b-body axle under an a-body (i.e duster /dart/demon)?
I found an article online where a guy moved the spring perches in 1/2" on both sides (to get the 43" a-body axle spacing) and bolted on a set of 255/60/15 tires with no issues. I forgot what size backspacing (4 1/2" ?) he used with his ralley wheels but according to him, this is a much easier swap without having to narrow anything. The axle is a couple inches wider than an a-body but is said to work okay as long as you get a wheel with enough backspacing to move the tire into the wheel well towards the springs.
I'm going to attempt the same swap since I have some b-body axles, a housing, and a 3.55 posi third member.
Anybody ever heard of this or tried this?
