B-Body spindles
tcp710
When using b-body spindle for the big bolt brake conversion, i was reading on bigblockdart.com that it uses a different lower ball joint. Can I just use an a body ball joint when installing them in my valiant?
i believe that you use the 73-76 lower balljoint, but it should say in the article.
